HAL.Sys.ShutDwnTempRangeExcd
Description
The temperature detected by the power and fan microcontroller is critically out of range. To prevent any hardware damanges, the system will be powered off in 1 second.
Remedy
Replace the fans if they have failed or improve air circulation around the system. When temperature has returned to normal range, power cycle the power supplies and the system shall power on again.
Severity
Critical
Message Text
Temperature is critically out of range. System is being shutdown by the Power and Fan microcontroller.
Applicable Platforms
